PatCouture
Hi All
I was wondering if it's possible to control what's showing in the bom depending on the assembly configuration?
I have a fairly big assembly into which I inserted a new module, The perfect way for that would have been to put all of this inside a sub-assembly then make the draft from this sub-assembly but since it has inter-part copies, and moving parts dependent from the master assembly I can't do that.
The only options I seem to have to control the bom are "Include only ballooned parts" and "Exclude hidden parts". the first one is a good start but to be able to have the right quantity I have to put a balloon at each and every instance of the same part... The second one won't take care of some parts because they are hidden by other ones. So I am hoping for another solutions other than those or to control it manually!
Thanks guys
Patrick
Thanks guys
Patrick
