BOM & Attributes.....
3dr
Automotive
I'm been using NX3 for a little while now and I am begining to look ahead to building some commercial part libraries and establish standard seed files.
This is what I need some advice on......
I am using standard attributes to build Parts Lists including the item no. because the standard "callout" isn't flexible enough in it's numbering schemes. Is there
a way to automatically apply the attributes to each part in my ass'y as I build? Ex: Can I assign a seed file to use as I create each part.....or can I use a utility of some kind to assign them to the parts after the design is complete?
I'm reluctant to start the libraries without a good strategy for this. It's a lot of work to have to key this stuff up on every job.
Thanks in advance for any help!
This is still a good case for GRIP. I have a program that will assign 4 attributes to a part file that we use in our BOM.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Are you using Grip to assign the attributes after the design is done?
I'm an autocad guy and used to use a programming language called autolisp to automate common tasks, commands etc.... They could be activated with a keystroke, menu or toolbar.
Is "grip" the UG equivilant for this?
Dave
Yes, GRIP is a basic-like language that can do simple things like add attributes to a file, basic file manipulation tasks, etc. It is not a maintained product, but UGS does make sure it will still function in new releases. They actually did some enhancements to it for the new NX3 plotting.
My GRIP program is run by the designer after he has finished the design.
Here is my simple program to add 2 attributes to a file.
number/rsp
string/titld(45),commno(10),aosno(22)
$$_______________________________________________
TEXT/'Enter Drawing Number',aosno,rsp
JUMP/trm:,trm:,,,rsp
call/'_upr_case',aosno
ASATT/PART,'DWGSIZ',aosno
TEXT/'Enter AOS Part Title',titld,rsp
call/'_upr_case',titld
ASATT/PART,'TITLE1',titld
commno = SUBSTR(&PNAME,1,8)
ASATT/PART,'DWG_NO',commno
$$_____________________________________________________
trm:
halt
The call is to a subroutine named _upr_case.grs. Here is the subroutine:
STRING/STNG1,STNG2(80)
NUMBER/N,str,lgth,loc
STNG2=&NULSTR
if/stng1==&nulstr,return
lgth=lenf(stng1)
loc=1
str=1
$$ Check for "$" in string
top: loc=fndstr(stng1,'$',loc) $$ find control character "$"
if/loc==0,loc=lgth $$ no "$" character found
do/loop1:,i,str,loc
N=ASCII(STNG1,I)
IF/N<97,N=N+32
STNG2=STNG2+CHRSTR(N-32)
loop1:
if/loc<lgth,N=ASCII(STNG1,loc+1) $$ get control character
if/loc<lgth,STNG2=STNG2+chrstr(N) $$ append it to string
loc=loc+2 $$ jump over cntrl char.
str=loc $$ reset start position
if/loc<lgth,jump/top: $$ if not end, continue
trm:
STNG1=STNG2
RETURN
Ben Loosli
Ingersoll-Rand
Thanks for the reply!
Where is the call to this program made from? Do you run
it from inside UG off of a Menu input or keystroke? Is it run from a batch utility externally?
Oh yeah while I'm on this subject... Is it possible to
assign macros to keystrokes?... and is there a list of Hot Keys for UG I could use to help speed things up?
TIA Dave
GRIP must be compiled before you can run it. You need to have both a development and execute license.
File - UG/Open - GRIP will run it internally to UG.
Yes, you can assign macros to user defined menu/button.
UG defined keys are in the ugii_env.dat file, I think.
Ben Loosli
Ingersoll-Rand
I have never compiled a grip before, but am trying to learn. When I ran the compile, and I got these errors:
PROGRAM : _upr_Case
1 STRING/STNG1,STNG2(80)
Error no. 24 in line no. 1: Missing dimension.
2 NUMBER/N,str,lgth,loc
3 $$
4 STNG2=&NULSTR
5 $$
6 if/stng1==&nulstr,return
7 lgth=lenf(stng1)
8 loc=1
9 str=1
10 $$_________________________________________________
11 $$ Check for "$" in string
12 top: loc=fndstr(stng1,'$',loc) $$ find control character "$"
13 if/loc==0,loc=lgth $$ no "$" character found
14 do/loop1:,i,str,loc
15 N=ASCII(STNG1,I)
16 IF/N<97,N=N+32
17 STNG2=STNG2+CHRSTR(N-32)
18 loop1:
19 if/loc<lgth,N=ASCII(STNG1,loc+1) $$ get control character
20 if/loc<lgth,STNG2=STNG2+chrstr(N) $$ append it to string
21 loc=loc+2 $$ jump over cntrl char.
22 str=loc $$ reset start position
23 if/loc<lgth,jump/top: $$ if not end, continue
24 $$________________________________________________
25 trm:
26 STNG1=STNG2
27 RETURN
Error no. 53 in line no. 4: Attempt to assign a value to a non-variable.
Error no. 84 in line no. 6: Invalid relational operator.
Error no. 70 LENF at argument no. 1 in line no. 7: Invalid field.
Error no. 70 FNDSTR at argument no. 1 in line no. 12: Invalid field.
Error no. 70 ASCII at argument no. 1 in line no. 15: Invalid field.
Error no. 59 in line no. 17: Illegal use of addition or concatenation.
Error no. 70 ASCII at argument no. 1 in line no. 19: Invalid field.
Error no. 59 in line no. 20: Illegal use of addition or concatenation.
Error no. 77 in line no. 27: RETURN appears in the main program.
Error no. 91 in line no. 27: Missing HALT in the main program.
NAME TYPE ADDR DIM
N NUMBER 0
STR NUMBER 2
LGTH NUMBER 4
LOC NUMBER 6
STNG2 NUMBER 8
STNG1 NUMBER 10
TOP LABEL 39
LOOP1 LABEL 146
I NUMBER 15
TRM LABEL 247
11 ERRORS, PROGRAM = 259, DATA = 23
Is there something obvious I did wrong? Thanks for your help!
The code snippet you are compiling is a subroutine, it must start with
Code:
 PROC[/dummy argument list]
Where 'dummy argument list' is what you are passing into the subroutine. Add
Code:
 proc/STNG1
as your first statement and it should take care of the errors.
Sweet! It compiled! But why did it become a .gri instead of a .grx? Can I just rename the file extension? I admit, I tried that, and when I run the grip (in NX2), I get this error:
Error 11 at line 9 in .
Internal error: memory access violation
CONTINUE TERMINATE
Should I give up and simply assign part attributes the old-fashioned way?
Kirsten,
As a sub-routine (easily identified by the underscore as the first character of the file name "_upr_Case") there is no .grx file generated. This file is dependent on the main routine to run (in this case, the first code example given by looslib). Compile the subroutine first, but don't try to link it (option 3 on GRADE). Then compile the main routine and after the main is successfully compiled, you can then link the main and sub-routine (option 3 on GRADE). At this point a .grx file is generated for the main, which internally calls the sub-routine when needed. Hope this helps...
SS
Just for clarification it should be noted that UG doesn't care what the file is named (the leading underscore is for us humans only). UG knows its a subroutine when it starts with PROC/'list' and ends with the RETURN statement. A 'main routine' will usually start with variable declarations and always end with the HALT statement.
