Bolting per VIII Div. 3
FC2008
GB
KD-621 in VIII Div.3 states that:
- The average primary stress intensity based on the root diameter should not exceed:
1/1,8 * S_y.
- The primary-plus-secondary membrane stress intensity:
0,75 * S_y
- The primary-plus-secondary membrane plus bending stress intensity:
S_y
Say that I am looking at the bolts on a flange.
The axial force due to pressure is the only force acting on the cross-section of the bolts.
Am I then right in saying that the average primary stress intensity is this force divided by the area of the root diameter?
Is there a secondary membrane stress in this problem?
thanks
If you are sure that you don't have anything on the bolted connection except pressure, then you are right (for a flange, for example, you may have local loads, flange deformation due to thermal effects or gasket relaxation, etc.).
The secondary stresses, as far as I know, are due (mainly...) to thermal effects.
Hope this helps and this is correct.
Andrea
