Bolted connections in cold-formed steel studs
ARKeng
51
I'm trying to check attachment of a steel stud to a masonry wall for uplift resistance at the end of a steel sheet shearwall.
Can anyone point me in the direction of how to find values for bolts (1/2" diameter) in shear through cold-formed steel?
If you're in North America, use the 2001 NASPEC and the 2004 supplement if referenced by the building code you follow.
