Bolt tension due to moment about a ring of bolts 2
Polecat
The TIA-222.G.3 standard says that the max tension on a single bolt (in a
baseplate attached to a pole) is calculated from the following formula:
1.02*pi*Mu/(n*Dbc) (assuming that there are at least 12 bolts and a minimal axial load is present)
Where:
Mu is the applied moment in inch-kips,
n is the number of bolts, and
Dbc is the bolt circle in inches
A dimensional analysis shows that the resulting answer is in kips of tension (or compression), but I cannot figure out how they derived the formula. TIA say that the bolt circle is treated like a ring of steel with a diameter equal to Dbc.
You can convert the total area of all the bolts into an equivalent area in a ring, and then calculate the section modulus of that hollow circle. Then you can do a M/S to get the max stress, which could then be applied to a single bolt to get its tension. However, I can't see where a formula that simply contains a pi/D ratio is anywere related to a section modulus.
Can anyone shed some light on this for me??
We're talking about a base plate that is nut supported rather than concrete supported, correct?
ASCE 48 and ASCE 113 has an equation for bolt force that is probably the same as the EIA when a monopole is used with a baseplate on leveling nuts. The general method is to find the MOI of the bolt group and find the bolt force as Teguci has done.
_____________________________________
I have been called "A storehouse of worthless information" many times.
@desertfox - good site that actually gets into the numbers - thanks.
From the site -
"It can be shown that [2θ j, j = 1,..N] are equally spaced on the unit circle (R = 1). Therefore, their centroid is at the origin and ∑ cos(2θ j)/N is its X-axis coordinate. Consequently,∑ cos(2θ j) = 0."
Using Lagrange's cosine summation, you don't need this leap of logic. You calculate directly that the sum of the cosines = N/2.
Using the cosine addition formula and Lagrange's trig identities, you can also show that ∑(j=1 to N); cos^2(2 pi/N x j + a) = N/2 where a is any initial starting angle. This tells us that the moment of inertia for a bolt circle, where you have at least 3 bolts, is constant regardless of the angle being looked at.
And I used to hate trig class.
