kaffy
- Jun 2, 2020
- 193
Good evening fellow engineers,
I am working on a rectangular frame (made up of steel c channels) which moves up and down and holds around 10000lb load. Previous engineers specified welds to keep the structural members in place.
I wanted to use bolted connections instead of welds but I was told that as frame is continuously moving and not a static structure, I shouldn't use bolts as bolts tend to loosen over time.
So my question is : Is self loosening of bolts really common?
I read somewhere that lock washers do not usually helps as axial tensions created because of preloading just flatten it out.
Are there any other ways to fix the issue and use bolts to attach the channels (picture attached for reference)?
Thank You
kaffy
Thank You
kaffy
