StressMan2506
Fellow Stress Engineers:
Is anyone familiar with this document (PRELIMINARY INVESTIGATION OF THE LOADS CARRIED BY INDIVIDUAL BOLTS IN BOLTED JOINTS)? One would expect that the 1st & last fasteners in a row would be equally loaded, the 2nd & penultimate likewise, and so on, but this is not what the method produces. This result is independent of the method used to determine fastener flexibility (denoted 'C' in the document).
NACA Tech. Memo 1135 (THE LOAD DISTRIBUTION IN BOLTED OR RIVETED JOINTS IN LIGHT-ALLOY STRUCTURES) has symmetry built in, but is formulated quite differently. Instead of a single flexibility for each fastener/plate combination, there are separate coefficients for the plate, straps and fasteners.
I am working on a project in which the use of Huth's formulation of fastener flexibility is stipulated. Huth produces values 'C' suitable for use in TN 1051. I am concerned about the inherent asymmetry in this formulation and cannot readily see how Huth can be applied to TM 1135.
Comments/suggestions please.
Thanks in anticipation.
