I want to develop a test to determine if a weld stud (already welded) meets its spec as a Property Class 9.8 fastener. From the ISO 898-1 spec, the proof load for an M10 at that class is 37.7kN. If I use T=F*k*d, where k=0.2 for steel on steel (nut is steel, stud is steel), then I should be able to torque the fastener up to 75.4Nm to acheived the proof load. Does this make sense, or am I missing something? If I put an aluminum plate between the nut and the fastener, does that change k?
Thanks,
Jeff
Thanks,
Jeff
