Bigbob1941
We have a 400HP, 480Volt, ID Fan being installed in a bag house for a 100,000 lb/hr boiler. The fan is made by Clarage and they have specified dampers on the discharge side of the fan only. There are no dampers on the inlet. The motor is powered by a VFD. It's designed so the outlet dampers will be wide open and the speed of the fan will be controlled through the VFD.
Is it possible to only have an outlet damper and not inlet dampers on an ID Fan? Wouldn't the lack of inlet dampers make the fan draw maximum current and pressurize the housing of the ID fan when starting?
