There is an insulated container of 100 m3 capacity which is 95% full with LNG (MM 16.4 kg/kmole) at -160 degC, saturated and at near ambient pressure (~0.2 barg). The heat ingress to the container develops 0.3 vol%/day of boil-off gas, resulting in the pressure inside the container to increase over time.
How do I calculate the pressure build-up after 1 day, 2 days, after x days, etc. before it reaches the PSV set point of 10 barg? Assume that no LNG is transfered out of / into the container during this time.
Thank you!
Thank you!
