BMX output to Excel (WF3 - Office 2007)
  • Thread starter Thread starter abrazors
  • Start date Start date
A
abrazors
Guest
<DIV =forum>
Does anyone know of a known issue where a BMX analysis cannot output graphs to Excel?
If you have tried this, you know that there are two options. The first way to transfer data to Excel is to plot in ProE and then select File/ExporttoExcel from the graph menu. This creates an Excel file with the data points and chart. The second way, by means of a config option, plots the graph directly in Excel during analysis.
I have never had a problem with either option in the past, but it no longer works. The only difference is that I have upgraded to Office 2007and Wildfire 3.0 within the last year. Not sure which is causing the issue of if it was some other HW/SW change that caused a conflict.
Please let me know if you have run into this problem and any possible resolutions.</DIV>
