CanuckEngineer
Hello everyone,
I recently commissioned a Kohler 500kW diesel generator set.
During the start-up the generator was block loaded with about 100kW and I notied some blue smoke in the exhaust.
Although it was faint, it was there for about 1-2 minutes and then dispersed.
Is this normal? I know blue smoke is obviously burnt oil, however how much should be apparent upon start-up, if any?
What are some possible causes:
1. Loose piston rings?
2. Valve timing?
Thanks for your help.
RK.
2. Valve timing?
RK.
