Hopefully, your liquid will remain in the blowdown vessel. If you don't have a dynamic simulator then run successive flashes at about 1-2 minutes interval. You should be trying to reduce pressure by half in 15 minutes. Calculate the mass removed during the interval, recalculate the liquid composition, then reflash. With LPG you should see the temp drop.
