bule99
- Nov 20, 2002
- 3
after checking some treads on this very usefull site it is time to post one myself.
Here is my problem.
A condensate train, starting from 3rd stage separator @ 2 bar, including booster pumps @ 9 bar and export pumps @ 80 bar, needs to be depressurised in case of fire.
Upon confirmed fire or gas detection ESD valves are closed, one on suction side of booster pumps and one on discharge side of export pump. All pumps are stopped and blowdown valve, located downstream export pump, opens. The idea is that all this happens simultaneously.
What would be correct initial pressure for blowdown calculations?
Obviously there are 3 different pressure segments in this condensate train during normal operation. Using the discharge pressure from export pump would be too conservative because other two segments have much lower pressure. I know how to calculate settle-out pressure for compressor sections but don't think it is applicable here, since fluid is liquid (stabilised condensate).
Another question is what happens with pressure when pumps stop?
No pumps - no pressure increase, so another extreme is to use the lowest pressure in the system, i.e. pressure of 3rd stage separator. In this case there is no need for blowdown because pressure is only 2 bar.
Finnaly, in order to initate blowdown simulation I need to add some gas to my fluid, so calculated flow is based on gas, while in practise it is liquid that enters RO.
Hope someone has some (practical) experience about depressurisation of liquid segments (with or without heat input)
Thanks in advance!
Here is my problem.
Thanks in advance!
