Blocking Radiation
eng86
8
Hi, I am making a heat shield to block unwanted waste heat from radiation. It is for an aluminum casting process. The shield is currently a sandwich of stainless steel plates with insulation board in between. Does anyone know anything else I can alter on the shield to help reflect/block the radiation? So far I've been thinking about surface finish.
Thanks!
Is the radiation ionizing or non-ionizing radiation?
a radiation shield does not require blocks of insulating pads between sheets. Just a series of sheets separated by a minimal gap works fine. It helps to include details that minimize thermal distortion.
Most thermal radiation heat transfer textbooks include a section on designing and analyzing heat shields. The effect of modifying the surface emmissivity is a standard deisng parameter.
Thanks for all your help guys! I'll be looking into what you said.
