A block valve before the PSV to isolate (and change it out)?
If you do, it should be car sealed open as a minimun. Also, it may be a good idea to have a second PSV (with CSO block valve) while you service the other one.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
