Block Insertion Nodes Showing 1
CRG
512
Has anyone had a compatibility problem with block insert nodes becoming unusually large when running AutoCad with Bentley AutoPlant. The nodes will shrink if I regenerate the drawings; however, they will not completely go away. The blocks that are creating the problems are objects that are 3D solids or surfaces. When attempting to print the objects, a very small box appears at the insert point. Any suggestions of how to suppress the insertion points?
Thank You TCARPENTER1
That was my problem.
