Apr 5, 2007 #1 M Marlon Wright Guest I'm a newbie on proe and im trying to blend a square onto a circle...im using wf proe...any help would be good.
Apr 6, 2007 Thread starter #2 M molsson Guest Split the circle sketch into 4 pieces using trim and you will be fine.
Apr 6, 2007 Thread starter #3 V vlad1979 Guest Could not find a specific circle to square blendbut it's the same principle as molsson said: http://www.ptc.com/cs/cs_24/howto/smd1311/smd1311.htm Just make a circle, divide it in 4 pieces, but be carreful do divide it where the corners of the square are, otherwise it will twist the blend, also make sure you have the start point in the same position on the circle and on the square.
