Snagglespree
When performing Modified Proctor Testing of soils, I am sometimes seeing odd results for the wettest test point. For example, I will add water for ~10.0 moisture to obtain . When pounding the Proctor "pumping" will begin to occur. Usually by the 4th & 5th lift, muddy water will "bleed" out the bottom of the mold. This water is essentially lost and isnt accounted for when plotting the moisture-density relationship and after oven drying the sample it indicates that the sample contained only 8-9% moisture as opposed to the original 10% that was added to the soil. This reduction in moisture, in turn, yields higher than expected dry densities and seems to imply that maximum density is at this moisture content. Visually, the material is not stable and you would expect low density values to get a true "curve". Instead, it produces a one sided curve and adding over 10% moisture would turn the material into mud.
Is there a method/accredited source that provides a way to account for this moisture loss or is that not necessary?
Also, whats the most appropriate way to determine the MDD in this situation?
