chrislaope
I have always had an impression that for a specific project, no matter what Code you are using, the final result designed by the two different Code should not off too far. However recently I am working on a non-building structure design that are not similar to building. I found a surprisingly big difference between the results by these two different design Codes.
The project is located at Fresno, California. The effective seismic weight of the structure is W=1273569 lb. The fundamental period is T=0.614.
By using UBC-97: from the seismic zone map, it falls in seismic zone 3, the control equation for base shear is:
V= (Cv*I*W)/(R*T) = 386230 lb session 1630.2 Eq.(30-4)
The redundancy factor for seismic zone 3 = 1.5.
By using IBC & ASCE7-05: Fresno, California has following value: Ss=0.507, S1=0.223, SDs=0.4713, SD1=0.2905, the control equation for base shear is:
V= Cs*W = 200078 lb ASCE7-05 Eq. (12.8-1)
Where:
Cs=SDs/(R/I) ASCE7-05 Eq. (12.8-2)
The redundancy factor for non-building structure that are not similar to building = 1.0 (see Clause 12.3.4.1).
Therefore the final seismic load effect on the structure for UBC design is about:
1.5*386230/200078=2.89 times as large as by IBC & ASCE7-05. The weight for this structure by UBC will also approximately doubled than by IBC & ASCE7-05.
Am I missed anything?
Thanks.
