jimbod20
Aerospace
- Sep 8, 2010
- 75
I think I have the correct subject line. Reference the attached hand sketch.
I have a casting with primary, secondary and tertiary datums E, F and G respectively. E is a surface defined by 3 datum targets. F is the secondary datum defined by 2 datum targets. G is the tertiary datum defined by one datum target. The location of the .250 inch diameter hole (datum B) is defined via basic dimensions from E, F and G. Size and position of .250 diameter hole is as shown on attached sketch.
My question;
I can allow hole B to move in one direction more than the other from datum point G. Position to E and F must be as shown on attached sketch. Can someone explain to me how I define position of B relative to G a different amount/magnitude in two directions?
My question;
