Biaxial Bending in a Glulam Beam 1
medeek
1,104
Let's assume I've got a larger garage door header (16' span) that is dropped down from the ceiling about 5', on the gable end of the garage. It's going to pick up certain amount of dead load and snow load from the roof, not much but some. If one were to simply look at the vertical loads the header size could be quite small, maybe a 4x12 DF No. 2 would be typical.
Now if I add in a C&C wind load that is perpendicular to the wall and assign some of the load to this header via the pony wall above it I have a beam that is loaded in biaxial bending.
I typically use Forte for a lot of my quick beam and header calcs but it does not let one apply a out-of-plane load to a glulam header. I am wondering if anyone has any suggestions for a different app/program that can calculate biaxial bending in glulam beams and headers. I contacted Woodworks and their sizer program also does not do biaxial bending or loads.
On that same note I was thinking about writing my own spreadsheet/program that will do the calculations but then it occurred to me that I don't actually know what equation to use for pure biaxial bending (no compression or tension axial loads combined). Do I use equation 3.9-3 with the first term disappearing or would it be more appropriate to use equation C3.9.2-1 with its first term disappearing? Notice the slightly different result since the first option would include fbx/FbE in the second term.
Would the Fbe term be computed with E'y min or E'x min?
A confused student is a good student.
Nathaniel P. Wilkerson, PE
@medeek(OP) - I don't do wood design that often.... but recently tried to familiarize myself with design of beam columns
by solving some of the problems from Structural Wood Design Solved Example Problems, AWC, 2005 Edition.
Problem #7 - Glulam Beam subjected to bi-axial bending: No axial load, torsion is ignored... Eqn. used is 3.9-3 with first term zero.
Problem #13 - Beam-Column, Sawn Lumber subjected to axial load + Major axis bending..... Eqn. used is 3.9-3 with third term zero.
Problem #14 - Continuation of Problem #13, Beam-Column subjected to eccentric loading in combination with other loads...
......... Eqn. used is 15.4.1 with all three terms non-zero. The calculations are exhaustive...
The code distinguishes between bending caused by eccenticity of axial load and bending caused by
loading acting on the sides of wood members......
For calculating CL about strong axis (X), use Emin about minor axis - Eymin.
Dropped-down header over garage opening needs to be designed for bi-axial bending when subjected to wind.......
