R
Raymon.D.Davies
Guest
I am trying to create a pattern using relations so I can offset the pattern in some cases and not in otheras seen in the attached picture.
I have 2 dimensions in the first direction and 1 in the second (this is same as 1 of dimension in first). I cannot seem to get this to work. I need this to be parameter driven and the pattern qty to be variable in both directions so I did not use a pattern table. Can anyone help?
