Bi-directional Diode for ESD 1
djkok
SG
How the bi-directional Doide with Zener voltage 5~7V can solve the ESD problem?Pls advise
I read somewhere that, for ESD protection, the junction capacitance of the zener can help as much, or more, than the zener effect itself.
Only in certain cases would it help. If the circuitry can deal with the -7V aspect... um perhaps an OPAMP that normaly runs +/- 5V?
A static discharge to a I/O line may be either positive or negative with a fast rise-time. Bi-directional ESD diodes clamp the discharge so the voltage on the I/O does not exceed the 5~7V to ground. This is usually sufficient to protect any semiconductor device, even if it has a lower voltage VCC. ESD diodes are quick acting which also means they have a low junction capacitance - this also reduces any affect the presence of the diode may have on a digital I/O signal.
