Artisi and Scipio,
I was tired when I wrote that, having some fun, but I do stand by all of it.
On your large pumps, where were they operating, at or near BEP or way off BEP?
If Specific Speed is low, single volutes do better because they exhibit less reaction to off BEP flows.
Good design and engineering you are correct about, select the pump correctly, install it correctly - no problems. "Correct" however is hard or not possible for many if they lack the knowledge. Some pumps are forgiving -some are not.
The information you guys gave is good stuff. Here is one small informal history that has taught me.
Over the past 10 years we have sold a specific pump in many applications. 30hp, single volute, overhung, close coupled, end suction. We have "noticed", actually tracked how long the motors on these pumps have lasted. Some last only a year, some 6 years and counting. In every case without exception, the back bearing failed. This confused me about the back bearing, but then I realized that on JP/JM motors, the front bearing is huge in anticipation of the shaft load, while the back bearing is very small. Radial forces vibrate the shaft and the front bearing handles it well because it is designed to, but the vibrations transmit through the shaft down to the back bearing and kill it, usually driving or wobbling it within its bearing race.
The key diagnostic is this, where the motor bearings failed early, 1-3 years, the pump was being used over a wide range of flows for long durations well off BEP.
So in this case, we feel that if the single volute pump is operated at or near BEP much of the time, pump motor bearings predictably last a long time If long duration runs well off BEP, short life.
A double volute, modified concentric volute, or pump with a diffuser is not vulnerable to this problem.
Therefore, if we have control over how the pump is used, and that use does not include long duration runs at flows far off BEP, we use the pump and like you, we receive good service no problems.
If we cannot control the pump's use, of if the pump will have to work long periods away from BEP, we go with a pump that cannot be hurt so easily.
PUMPDESIGNER
