BEST WAY TO MAKE THIS?
imagineers
CA
So this is a cover for a small radiator for a computer. Now, I was wondering can this be made with a two cavity mold, basically, pull tom and bottom and side actions for front back? what about the lowest draft angle, as 5 degrees over 128mm distance changes the width too much from top to bottom, I need around .5 or 1. I know theres alternatives such as a front back mold, split in the middle and maybe ultrasonic weld or clip features, but would be nice in one mold.
 http://files.engineering.com/getfile.aspx?folder=32eb3091-bae3-4ec3-85a1-4c1c3f50f39a&file=shroud.PNG
Not sure what you mean by "two cavity" mould - unless you want to make two at a time?
For me, I would see no problem moulding it. Side cheeks, stripper plate ejection with some additional pins ejecting on the inside of the base. Commercial polish finish. 0.5 to 1 deg should be fine for the core. The outer faces can be of zero draft. Direct sprue feed onto base (or a hot tip).
You might get movement of the core, degree of which will depend on what you make it from. Cycle time likely to be extended due to limited cooling in the core (although it might be 3" thick?).
As an an aside - countersunk screw holes are not good in plastics. The wedging action cause by the inevitable line contact on the countersink will cause rapid creep, if not cracking.
Cheers
Harry
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
Unless he was planning to split the part down the middle and glue/weld two halves?
Cheers
Harry
Thanks Harry, great information.
I was thinking of using PC/ABS blend
PC/ABS should be fine. Note that only the core needs polishing to assist ejection. Probably be ok with zero draft, but anything more than zero would be useful - outer faces can be any finish.
H
thing is that even if I draft only the inside and not the outer surface, I end up with about 1mm thickness difference at the top as opposed to the bottom, 4mm vs 3mm because of the draft 0.5 degrees. Is this too thick, or maybe an issue with sink marks or cooling issues or deformation?
 http://files.engineering.com/getfile.aspx?folder=456c6096-cc2c-41ef-810c-0113cb80b9c0&file=draft.PNG
Just leave it as zero draft, but get the core polished/smoothed off (not gloss), just get any cutter marks out. Polish in line of draw. Toolmaker should know what to do.
PC/ABS has minimal shrinkage as it's amorphous - there is only the thermal shrinkage. Sink marks are like warpage in glass-filed material: usually designed in. Your part looks ok. (You may get a witness of weld/flow lines around the holes).
You should add a small rad to the bottom inner face corners as well. Sharp corners not good....
H
