Mgobluecw2
So I'm having trouble cutting a thin (<1.5mm thick) sheet of expanded PTFE laminated to a polyester/polyethylene backer. The kicker is the sheet is half an inch wide and I'm tying to cut circles with a diameter of .4 inches. I'm using a cutting die, but am experiencing tearing of the backer instead of the desired clean cut. Any suggestions? Would shearing the cutting die or increasing the tension of the strip help create a cleaner cut? Any help would be greatly appreciated.
Thanks,
G
Thanks,
G
