Best triangular shape for a support underneath a steel shelf
Garry1234
Industrial
Jun 29, 2018
6
Good day,
I am wondering if someone will be able to please assist me? I am currently trying to redesign a support that is spot welded underneath a steel shelf. (Please see images attached). The current design uses a large quantity of material and I do not believe that it is very strong. I have also attached a proposed design - that I feel is extremely strong and is a better design.
My question is - Is the triangular support the best to implement? what is the best angle to use for the triangular support and the best height of the triangle so that I can use the least amount of material whilst keeping the shelf extremely strong?
Does the height of the triangle matter with regards to strength in a bending force?
Thank you very much
 https://files.engineering.com/getfile.aspx?folder=7b03a820-46ad-4ed0-b380-2e8736601497&file=image_123923953.JPG
