Hadrianswalls
Bioengineer
I was wondering if you would be willing to answer a question that has been brought to my attention regarding water quality applications in a closed loop radiant heating using PEX tubing and a tankless boiler.
Specifically, the discussion has been; what is the best unreactive solution that could be run in the system without potential leaching of platicizers in the PEX tubing and thus wanting a long lifespan of the tubing and boiler without corrosion.
The possible fluids that have been suggested are;
1. Tap water
2. Distilled Water
3. Propylene glycol and tap water
4. Propylene glycol and distilled water
5. Other unknown combinations.
6. DI water
Some have stated that distilled water causes leaching and is not good in PEX tubing. I do not know. I know that tap water has minerals that may build up but to what extent I do not know.
With longevity of the system in mind, may I ask your expert advice on what path I should take or what solutions may be best suited for use in this system?
1. Tap water
2. Distilled Water
6. DI water
