Best Practices - Fix contraints
  • Thread starter Thread starter superchiwawa
  • Start date Start date
S
superchiwawa
Guest
Quick question: I consider using the Fix constraint in general bad practice, akin to a blunt tool or duct tape solution, and a last resort.
Whether it's a sketch or an assembly, when do you condiser using the Fix constraint GOOD PRACTICE vs taking the time to actually constrain properly in the long run?
A little personal experience context:....
I know in some places I worked, for assemblies, they prefered to snap items into place and then fix (Catia v5) them because it was easier than putting in the extra thought/effort (and time) to constrain, but this also created problems where items would be out of place. Not a good thing when they are the support for exps-enive multi-axis CNC machining (shifted origin - tooling in the wrong place...)
Another example was that for performance it was mentioned that it may be better to position parts, then just fix them (Solidworks). Maybe justified, but if you need to do any edits (eg add a part), you risk losing all the other positions because you have to delete the fix constraint
Lastly another pet peave of mine is opening sketches to fiding fix constraints, particularly with models imported from other systems as a fast fix. Later down the line if you want to edit the part it's just a nightmare
(I'm definitely in the do it right first time belief camp. I also understand on occasion it may be counterproductive in the short term (time time time), but belieie it always affects you in the long run.)
Got any valid arguments to convince me otherwise? Or do you agree with me?
Cheers
S.
I agree with you.
I also like to see the actual constraints which often show how the part was designed (the design intent).
But I have to admit to using FIX sometimes to prevent accidentally moving or resizing things, especially geometry that I've imported.
I think as a general rule having fully defined sketches is the best approach. How do you know it's the right size if you just go off and fully define without dimensions? If you are already taking the time to type in the box (but not add a dimension) I'd argue that's an utter waste of time. The whole point of parametric software is to be able to go back and easily make changes that ripple through designs, if everything is fixed this is not going to happen. Also how you fully define it is important to capture your design intent and make editing things easier and quicker.
You are right that technically fixing components in an assembly will save performance as it's not calculating several mates, but how do you know it's in the right position? What happens when the design changes? The performance saving would be so minor the downsides make it not worthwhile, especially if following common assembly structures and making use of things like large assembly mode and speedpak if necessary.
Fixing however does have some uses when working with freeform curves or imported files.
