I am huge proponent of Non-Sig part numbers, with carefully predefined field hierarchies for description creation withing families. I also like pre-defined ranges for specific types of parts. Here is an example of a 7 number system. See linked PDF here:
In this scheme, each part family has a predefined range from which you can create non-sig part numbers. For instance, the 4th part in the SB family that is created would have a part number of 241-0004. So the only intelligence in the system is that you can look at the prefix, and know what sort of part you are talking about. This had advantages for inventory control and item handling in the facility.
Also, each family has a predefined sequence of descriptive fields, based on the family.
Description Field 1 (Primary) - 'Shaft' for the SB family, but 'Hardware' for the HW family
Description Field 2 - Could be 'Drive an SB family part, but 'Screw' for a HW family part
Description Field 3 - Could be 'Threaded' for an SB part, but Cap for HW part
Etc.
Result:
Shaft, Drive, Threaded, 1.50", 60"L
Hardware, Screw, Cap, Socket Head, 3/4"-10, 4"L. Full Thread
So here is my question. Let say I have this part 241-0004, and it can be made from a variety of materials. 416ss, 316ss, C1045, 17-4PH, 4140, Nitronic 60. Currently in our system we would have a single part number, but material codes that are attached to the part number. This is the the legacy ERP system is structured. So, the actual definition of the part would be 241-0004-1197, where 1197 is the code for A582-416SS. Is this bad practice? In reality, material codes are a version of a smart numbering system. Should non-sig systems be to rigid as to exclude materials codes? If we hold to this, that would mean I would need 6 part numbers to cover this one shaft design that can be machined from 6 different alloys.
Etc.
Result:
