Best fitting parts
Alan Lowbands
Aerospace
GB
Could anyone tell me how I can 'best fit' two hole patterns ?
I have a report with the actual hole positions for both parts and need to see if they will go together.
I have drawn out and made both parts but can't find a way to best fit them using constraints.
Any help (as always) would be appreciated.
thanks
Alan
I was totally wrong and I haven't got it :(
Could anyone help please.
regards
Alan
Hi.
Would you share a pictures of what you have and what you're trying to achieve?
Thanks for the reply.
It's basically two plates with bolts holding one to the other.
I have the positions of the clearance holes and the threaded holes but there are positional errors in both.
what I want to do is model the clearance holes in to a plate. add screws at the reported positions and best fit the two to find the clash positions.
There are 48 holes in each plate so I didn't want to model it up until I found a way to best fit them.
A simplified sketch is attached that hopefully shows what I mean.
regards
Alan
 https://files.engineering.com/getfile.aspx?folder=fb1a0866-d6b0-4f27-ae9f-1f5356ba8dac&file=grab1.jpg
