Jun 30, 2010 #1 mabdelmoniem82 Mechanical Joined Jun 2, 2010 Messages 5 Location EG I need to what is the best practice to calculate the bend allowance for a press brake with different tooling. Help will be appreciated. Thanks in advance.
Jun 30, 2010 #2 MikeHalloran Mechanical Joined Aug 29, 2003 Messages 14,450 Location US You need to _measure_ the bend radius you can actually achieve, with the tooling you intend to use, working the material you intend to work. Then you can work backwards from the actual bend geometry to find the right parameters for any method you care to use. Mike Halloran Pembroke Pines, FL, USA Upvote 0 Downvote
Jun 30, 2010 Thread starter #3 mabdelmoniem82 Mechanical Joined Jun 2, 2010 Messages 5 Location EG do I have to check the bend allowance at different angles too. using the same tooling, material and thickness Upvote 0 Downvote
Jun 30, 2010 #4 hydtools Mechanical Joined Apr 4, 2007 Messages 3,265 Location US Try this: http://www.engineersedge.com/bend_allow_calc.htm or this: http://www.sheetmetalguy.com/bend-allowance.htm Ted Upvote 0 Downvote
Jul 8, 2010 #5 berkshire New member Joined Jun 8, 2005 Messages 4,429 Location US Another one that helps is bendworks http://www.ciri.org.nz/bendworks/ B.E. Upvote 0 Downvote
