Andersen07
Industrial
Hello everyone, I'm a new NX user coming from Solidworks.
In the company I work, we make sheet metal housing for acoustic isolation. It's like a box with its sides covered by acoustic foam.
The "box" has 5 sub-assemblies called "pads": front, left side, right side, back and top pads. The problem is that the boxes are not standard, they're all custom-made depending on customer needs (the only thing that changes is the overall size), so it changes on every order.
So, lets say we have a custom order for a 0.6 X 1.0 X 0.8 m (width X depth X height) box. Front and back pads will be 0.6 X 0.8, both sides will be 1.0 X 0.8 and the top pad will be 0.6 X 1.0. All of the pads are modeled the same, same thicknesses, same bends, same holes and detailing features, except for the overall dimension. The acoustic foam should follow the dimensions of each pad.
I'd like to input only 3 values: width, depth and height of the box, and have NX to update everything. Also, I want to make only one model for the pads, in a way that if I change one of them (adding a new hole or changing a bend, for example), all of the other pads update as well. At the same time, the pads have to be different in size.
What would be your approach on that?
I though of part families, but couldn't figure out how to make it work for this specific case, also I read that part families should be used only for standard parts that don't usually change and that it is not recommended to nest part families.
Thanks!
Thanks!
