I have another good one for you.
Recently I started a project in metric system.
The client wanted all drawings in imperial system.
So I used the tools in Railtrack to convert all my alignments.
It worked perfectly, even the turnouts were scaled correctly...
correctly? well I lost the connections....
Is there a way to just connect the alignment with the turnout or do I have to REINSERT every imperial turnout and then remake the connections?
In short, Do I have to REDO every connection when a conversion is made?
