As you have clarified the piping you are dealing with is pvc, I have noticed that over many years there has been some apparent sort of flip-flopping by some authorities and manufacturers around the world as to how deviations from line and grade should be accomplished with this piping. It therefore may be advisable to get the specific manufacturer(s) on record as to exactly how this should be accomplished on your project. The latest from allegedly a very large pvc pipe manufacturer(I have noticed that has been in the news much over the last year)appears to be now at
. What is said on this particular site, I accessed today, includes the following, much of which may be interesting for readers in light of some expert advice on this thread, and with regard to probability of accomplishment in practical underground construction environments:
“A joint that is assembled per our recommendations will exhibit a gap, in which the beveled end of the spigot is stopped short of being fully bottomed out in the bell.”
“…’s standard installation recommendations call for no axial deflection at the joint. This recommendation emphasizes the fact that any intentional change of direction should be accomplished through a fitting connection or by bending the barrel of the pipe rather than offsetting the pipe joint. “and later again in multiple locations:
“… does not recommend any deflection at the joint for any of our products.”
“The pipe should be assembled above ground, in a straight line, then curved and laid in the trench. All curvature results from the bending of the pipe lengths. There is no deflection at the joint.”
“Brace the bell while the spigot end is pushed under the gasket, so that previously completed joints will not be further inserted.” And repeated:
“Lastly, there should be no axial deflection at the joint. Bending the pipe, rather than deflecting the joints, should serve to accomplish small changes in direction.”
“… pipe does not meet AWWA C-111; this standard is for Ductile Iron Pipe.”
“The joint design meets ASTM D 3212 performance testing requirements, thereby assuring a watertight joint that does not exceed an infiltration / exfiltration allowance of 25 gallons / inch diameter / mile / day.”
With all this being said, it is my understanding field splitting failures of pvc pipelines, with and without eventual tapping involved, have incidentally been blamed (or explained away?) on the Contractor (or other installer) bending the barrel of the pipe. Go figure! [While I guess it could be argued a pvc sewer force main would not have as many required drilled holes or taps in the pipe wall(that are obvious stress concentrators)as a water distribution piping, pvc force mains can (as a practical matter) also can have some stress concentrations and also are possibly more subject to cyclical stress/fatigue issues, due to pumps cutting on and off etc.]
