Hi respected engineers!
I face a design issue in which i would like assistance due to my lack of experience. I want to connect a CFRP tube with metal inserts at each edge (the metal fittings are of smaller diameter than the CFRP tube) and the proposed joint is an adhesive bonded one. After searching on the net, I found that these joints are mostly used to transfer axial-torsional loads. Some preliminary calculations done, have shown that the peel and shear stresses are too high to sustain a bending load, as well as the out-of-plane strength of the CFRP tube is also low. Just to provide more info, the tube will act as a cantilver beam of approximately 600mm, and a max moment of 60Nm must be tolerated. What type of joint would you advise me to use to transfer this moment? Could this be done with some alternation of the design and still use adhesive a the connnection or is it mandatory to use a mechanical type connection?
