RHTPE
- Jun 11, 2008
- 702
I am involved with proposing an alternate connection between an architectural concrete facing and a structural wall, with 2" of EPS insulation and a waterproofing membrane between. This is a cast-in-place "sandwich" wall. Rather than use the double-headed shear studs spec'd by the EoR, I'm trying to integrate the concrete-to-concrete connection with the form ties.
My connection uses 1/2" coil rod screwed into the coil ties used for the structural wall, and then connected to coil ties used for the architectural facing formwork.
Critiques of this design (the sandwich wall) are unneccessary - it is what it is and I cannot influence it.
Each 1/2" coil rod (root diameter = 0.42") carries 586 lbs of vertical gravity load (the weight of the facing). The yield strength of the coil rod is 110 ksi. Assuming the rod to be fully fixed each end by its embedment into the concrete, I figure the maximum bending moment to be 586 in-lbs, or about 0.73 Fy. Shear is of little concern (0.03 Fy). From AISC 8th edition I find allowable bending stress to be 0.75 Fy.
My question for the group: Am I missing anything here?
My familiarity with AISC 13th edition is somewhat limited.
Ralph
Structures Consulting
Northeast USA
