P
proewannabe
Guest
I've looked to see if there was some information on this and couldn't find anything posted on the forums. Hopefully a veteran in ProEcan assist me here.
I'm working with a sheetmetal part and am currently detailing the drawing. I've used the show/erase command to use parametric bend up/down notations. Our company always uses bend down notations because when we use stainless steel, we always want the "shiny" side of the metal to be towards the outside.
My question is if a part is designed so that the bend is up instead of down, is there a way to change the notation to keep it parametric? Currently I have a symetrical part that hasthe bend notationsymbol as "up". I need this notationsymbol to read "down" and yet remain parametric. I know how to change the text manually, but that's not what I want to do. Any suggestions/advice?
