Bench footing how to determin lateral pressure
gasma1975
53
I have a project where I need to lower the basement floor. I want to do a "L" wall in front of the existing foundation wall. If the existing wall carries a linear load of "w" what will be the lateral pressure under that wall which will push on my new "L" bench footing ?
Thank you,
gasma1975
1) How high will the step be at this L-wall?
2) How close to the existing wall footing will the back of the L-Wall be?
3) Ideally you'd have a geotechnical engineer advise you on this. Otherwise, perhaps a method like Boussinesq might suit your purposes.
4) When I've done this, I've tried to dodge your question by doing one of the following:
a) Underpinning the existing wall footing which is costly or:
b) Placing the step far enough from the existing wall footing that I'm confident that the L-wall won't see appreciable load from the wall footing.
As you probably know already, these L-walls aren't great for overturning unless they're tied back somehow.
An L-shaped wall for deepening the basement will have overturning and sliding problems unless founded deeper below the proposed basement level. But, a deeper L-shaped wall footing will create more of the same problems. As KootK mentioned, consider underpinning the existing wall. There should be many other ET threads about this same topic.
