agrimm0105
I work at a coupling threading facility where we have several CNC lathe machines. Originally a timing belt is used to turn the chuck. This is the best option in theory because the metal shavings are supposed to be prevented from going into the motor area by walls and wipers. But after years of operation the walls no longer block all the shavings and some become lodged into the belt.
To solve this, all the timing belts were replaced by v-belts; but this would decrease the precision of the machines. I was wondering if there was a type of timing belt that could be as resilient to shavings as a v-belt.
Both timing and v-belts have the steel wires inside the rubber for tension purposes so I am skeptical about the v-belts being a better option.
