Omar7amdi
Automotive
- Sep 11, 2016
- 15
Suppose this pulley is latched to a motor's shaft residing on the floor. On the ceiling there is a similar pulley hanged on a hook. At the center of the belt's height there is an object carried by the belt. When I ran the motor sometimes the belt's teeth does not lay on the pulley's groove which causes the object's position to not be coherent with the motor's rotation. I tightened the belt and the problem still comes from time to time? The motor is moving forward and backward.
is there any idea how to solve this problem?
