I've wrestled with leg designs through the years, and am just now looking through some of the details of Bednar's method.
Reference: Pressure Vessel Design Handbook, 2nd Edition.
The issue I find is than an unbraced leg subject to lateral loads has to have applied moments somewhere. The leg could be assume "fixed" to the vessel and pinned at the ground, or "fixed" to the ground and pinned at the vessel or fixed at both ends, etc. but can't be pinned at both ends. It seems Bednar assumes 3/4 fixed to the ground, 1/4 fixed to the vessel- which he handles by placing the lateral load at 3/4 of the actual height.
So, at the bottom of Page 147, he gives an equation for moment in the leg that includes Fx3/4L term that represents this assumption.
On Page 151, for the moment in the weld to the shell, he includes an FL/4 term that also fits this assumption.
The problem is, in the design of the base plate, Page 149, he takes the moment on the bottom of the plate as only being due to the eccentricity- no Fx3/4L in that term.
So am I missing something here, or did Bednar blow it?
If you try to include that 3/4FL moment on the base plate bearing, then you just can't make the base plates big enough per his design procedure.
Yet, I can't see any reason to exclude that moment, either.
Any ideas?
Any ideas?
