We have received some bearing tester data that was taken on our fan bearing. The readings were in the dbm 40 & dbc 21 range. dbm was defined as max shock value in decibels, and dbc as average shock value in decibels.
I do not know what "tester" was used.
I do not have a clue as to what these values mean, does anyone have an opinion? I wonder what levels would be classified as normal and what levels would indicate a problem.
