Tough question. You might try bearing forum.
Where are you reading the part number from?
What manufacturer is the bearing (should be stamped on the bearing)?
Is there an AFBMA number (including suffixes) listed on the motor nameplate? (should start with 60BC03... what comes after that?)
What type of motor?
** If this is simple horizontal motor with no special requirements, I'd think any 6312 2Z/C3 would do. When you replace the bearing, put compatible grease into cavity (half full) as what bearing manufacturer will provide within the new double-shielded beairng. (usually Polyrex EM will be fine... compatible with most)
(2B)+(2B)' ?
