Trillers
- Feb 14, 2011
- 66
A client is replacing a modular FRP water tank with another of the same dimensions and capacity. The original tank was supported along its base (including cross bracing) by MC7 c channels sitting atop grade beams (plinth) 3' high. The new tank will sit on MC6 c channels.
The client has asked to confirm that the MC6 can safely bear the load.
In short what is the load capacity of a uniformly loaded and Uniformly supported c channel?
The channel will lay on a flange and the upper flange will support the tank.
Can someone lead me in the right direction to figure out the channel capacity under this loading condition?
The channels are adequately restrained against buckling and torsion.
Would it be proper just to calculate the web capacity simply as a structural section and neglect the flanges?
