Bearing Reactions
Jiks
GB
I would like to know how I can work out bearing reactions ( radial and axial load) if I have a shaft to which a helical gear is attached, supported by bearings on either ends. If I apply a torque to one end of the shaft how do the bearings see the load assuming the gear is transmitting the torque. My main concern is the calculation of a tangential load which acts away from the axis and the radial load (?) which is due to the weight of the gear and the shaft. How are they related and how do I resolve it to find the radial and axial load on the bearing? Thanks.
Such a basic problem.
Sounds to much like homework .............
Remember...
[navy]"If you don't use your head,[/navy] [idea]
[navy]your going to have to use your feet."[/navy]
Break the loads down to normal and tangential components on the face of the gears (x,y and z components). You'll need a coefficient of friction and you will need to know the angle of the helix. Do your free body diagrams with those loads.
