Bearing prelaod and inner ring rotation 1
FALLU
1
Hi everybody,
Does someone have any idea what the preload of a bearing 6204 2rs installed in hub tube with interference fit assembly should be and how it can be measured? We have a customer complaining for inner ring had to rotate "by hand" and we would like to have a criteria or method of measurement to contain the issue.
Thank you very much in advance.
 http://files.engineering.com/getfile.aspx?folder=c30519af-d73a-4d57-b160-58770fb004dc&file=Capture.JPG
You need to call the bearing manufacturer. They can answer this for you in about 10 seconds.
