Bearing Grease for Umbilical sheave bearing?
pacesetter
CA
I have a NNF Bearing from SKF that is part of a sheave. What would be a suitable grease for relubrication? And, what properties of the grease are important?
The bearing supplier has reccomended Mystik JT-6. However, they could not provide any reasons why they use this grease.
SKF indicates that the bearings come filled with grease that have a lithium thickener with diester base oil. The base oil viscosity is 15 mm2/s at 40 °C and 3,7 mm2/s at 100 °C.
I am also considering using Marson Liplex 39872 grease, but the viscosity is much higher.
Thanks in advance
Mystik JT-6 >>>may<<< be OK.
The only info I found refered to it as a multipurpose grease with "Hi Temp" properties but no data. Do you need hi-temp qualities?
The SKF website will direct you to recommended greases.
I'm partial to Mobil SHC greases in the NLGI grade suggested by the bearing manufacturer.
