Bearing effective interference
H.Abuzied
EG
do anyone have an idea about :
how to calculate value of bearing effective interference ?
what is the difference between bearing internal clearance and effective interference ?
Thanks,
Thanks Tmoose
I've seen NSK cataloge before , im already using their equations however , when i tired to get value of effective interference i got a negative value ,which is not acceptable for my calculations i need a positive value...please correct me if im wrong...effective interference = red. in interference due to used fit -(red. in interference due to acting load + red. due to temperature change + red. due to surface finish ) ?
alos, i do have 2 more questions concerning calculation of red. in interfernce due to temperature change :
1-
in the attached photo ,the mentioned term for linear expansion coefficient ,was omitted in the final simplified form of the equation , the final used equation was 0.0015 . ΔT . d...where did the value of α been substituted ?
2- when calculating value of effective interference between housing and bearing outer ring, shall i use red. in interference equation = (α1-α2).ΔT. De or (α1-α2).ΔT.D?
Where De is mean outer race way diameter , D is outer ring diameter.
Thanks again for your help
What is "happening" at installation ? Which ring(s) are interference fit, etc?
What do you reckon is the ΔT of your inner ring/shaft in operation?
What do you reckon is the ΔT of your outer ring/housing in operation?
"What is "happening" at installation ? Which ring(s) are interference fit, etc?"
[ul]
[li]I haven't started installing bearing yet......right now I'm calculating value of force needed to pull out / press bearing from its location , which depends on value of effective interference.[/li]
[/ul]
[ul]
[li]type of used fit between shaft and inner ring : interference fit. while, that between housing and bearing outer ring : transition fit[/li]
[/ul]
"What do you reckon is the ΔT of your inner ring/shaft in operation?"
[ul]
[li]ΔT is the difference in temperature between shaft and bearing inner ring during inner ring/ shaft operation (10° C)[/li]
[/ul]
"What do you reckon is the ΔT of your outer ring/housing in operation?"
[ul]
[li]ΔT is the difference in temperature between housing and bearing outer ring during outer ring / housing operation (10° C)[/li]
[/ul]
In the ΔTs mentioned, you need to know what is hotter, and what is cooler.
A hotter housing tends to reduce the effective interference.
A cooler housing tends to increase ( tighten ) it. To the point playing a cooling fan on a hot bearing housing to cool it off can result in excessive interference and possibly dangerously reduced internal clearance.
